IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6161 Views
  • 14 replies
Resolved! Speed Dial
Hi everyone!Is it possible to assign speed dials to 1,2,3 buttons with CUCM 6.0.. I've heard something about it, it was referred to as Dial by Button, not sure thoughThank you in advance!
I have a big problem with new ip phones 6911. I have a cluster installation of Unified Communication Manager 7.1 . I have a lot of 6911 installed and they work correctly but I can't set busy trigger to value 1. Anyone know a way to do this? My custom...
Hello Gurus I want to know is there any way to play welcome prompt and Menu selection option without AA and CVP /IP IVR. I have three components 1.       CUCM2.       Voice gateway3.       IP Phone.Whenever someone will call, call will listen some p...
Hi ,   We are running  CUCM 7.1 and planning to migrate all the users to a different cluster. The new cluster is also CUCM 7.1 but not exact version.IS there anyway we can migrate the speed dials ?Phones are running SCCP.RegardsSiva
stharmal by Level 1
  • 393 Views
  • 1 replies
Guys,I'm trying to establish connection from my FXO on 2801 so that I can make external calls as well as calls to extensions in the company. When I dial an external number 9.......... my phone says connected and there is a continuous tone but no ring...
Hi there,I have a Cisco phone with two DN's on CCM6.1. Just wondering if youo know how to make the "phone busy" as opposed to "line busy". In other words, if I am on a call on one of the DNs. The second DN should also appear busy to the caller.Your h...
anujnaidu by Level 1
  • 2957 Views
  • 13 replies
