IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6071 Views
  • 14 replies
We have the attached setup (attached)  that we have local H.323 network, which includes Cisco 3845 (Gateway), Cisco CVP 3.1 (IVR), Cisco Call Manager and IP Phones.The gateway was having PRI ISDN Ports and was working fine end-to-end. Then we needed ...
luai by Level 1
  • 991 Views
  • 0 replies
Hi All,We are trying to push ring volume to our ip phones. Let's say that there are different levels of calls that are triggered by a own written application, this application handles several actions, and when action 1 is activated, several phones sh...
p-vincent by Level 1
  • 604 Views
  • 4 replies
I'm interested in formatting the caller ID information that comes in from our PRI.  I've received requests to make the output more readable for the users.  When a call comes in, we see "1234567890".  I would like it to show the same number, but show ...
We have timed partitions setup at a school that only allow calls to ring classroom phones before and after classes. It is working. If for example you would call DN 2010 during class hours it would hit a CTI Route Point with the same DN (2010) that is...
johnnywan by Level 1
  • 269 Views
  • 1 replies
Dear all,I’ve Cisco Fax server with an SR140 and I would to configure 2 SIP trunk, 1 for each CallManager. I would liketo do that for redundancy. I’ve the possibility to add only 1 ip address on the SR140 config panel. Somebody can help me ?Thanks
fdemierre by Level 1
  • 847 Views
  • 2 replies
