IP Telephony and Phones
Labels
I use Openvox A800P with 5 FXO and 2 spa8000. Sometimes i heared some noise in different telefones. But anoter time they works correctly. How to remove this noise?There are Gateway settings and logs in the attachment.
rezzonans by Level 1
  • 313 Views
  • 1 replies
Hi Folks,               This is the second time that I run into this issue. A weeks back a customer called me at explained that they have a fxs card with 4 ports with 4 analogs phones connected to them.However, they cannot make simultanous calls(two ...
Dear AllWe have a voice gateway  connected via 1 E1 (TDM) with the 20 channel DoD and 10 DiD. We will replace it with SIP triunk (IP based Network) and the customer require the same configuration (20DoD+10 DiD) Is it possible to do that with SIP Trun...
