IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5824 Views
  • 14 replies
We configured LDAP at our CUCM 6.13 cluster. However, the corporate directory is not shown as an option under the directories button. The "url directories" under enterprise parameters has the following:http://cucm-ip:8080/ccmcip/xmldirectoryinput.js...
Hi,I have intermittent CME MWI issue with the MWI status 'failed' and want to know how to reset the status to able to change to 'subscribed'Advise please,env)-2811 12.4.22.T1-CME7.0.1-CUE7.0.2-CME, sip-ua with CUE IP address, configure 'mwi sip' unde...
cjrchoi11 by Level 1
  • 579 Views
  • 4 replies
Hi, we have 2 setups CME and CM.I need to take one phone from CM and register to CME.I did1. **##** but old CM retain.2. # then 1234... but it didnt ask me to remove old configs. so it re-registered to CM and firmware got updated.3. Erased config (pr...
pgamage by Level 1
  • 495 Views
  • 3 replies
Hi all, We have a psenario having ccme conncted to remote end PBX through sip trunk.I can make voip calls from here to remote.I need a solution to reroute the calls through pstn automaticaly if this voip line is down.If anyone having solution fo...
Hi Guys,I am trying to get some voice translation rules working for incoming calls for one of my clients. This is for incoming international calls, the telco is stripping the leading 00 therefore only presenting the 44 in the case of incoming calls f...
Good Morning Netpro'ers :)I'm really hoping someone can solve my dilemma. I have a range of phones that when dialing externally i wish them to use the g729r8 codec. I know how to do this on the gateway under the voip DP with the voice class this is n...
