IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5900 Views
  • 14 replies
Hi All, I know that Cisco Unified Communications manager business edition has the capability of generating reports however, I looking to generate a report that will show my dial plan such as what extensions are broadcasting to what extensions or hunt...
The default uc500 config (using cca) puts fxo ports in a hunt group and applies the hunt group to the pots dial peers.Problem is if one fxo trunk is oos, the hunt group does not hunt around .ie unplug trunk 1, and outbound calls are busy signals. Har...
I have 5 CCM clusters with 5 Corporate Directories. Is it possible to create a replication agreement in SQL from one CCM to the others and sync the directories? I'm tired of updating 5 CCM directories.
cmesser by Level 1
  • 405 Views
  • 2 replies
