IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6058 Views
  • 14 replies
Resolved! CCM conference
Hi all, do somebody know, how many conference connections can be used on 7835 MCS server with CCM 4.2? I dont have transcoder, but I think that server alone can mix some conferences. If you know link it would be nice. Cannot find on cisco.com even if...
HiI have the following ennvironement:for outgoing: MOCS---IPIP GW---h323 Gateway----PSTNfor incoming: PSTN---h323 GW---CCM 4.2---SIP Trunk---IPIP GW---SIP----MOCSThis scenario because the h323 GW is not supporting SIP over TCP.The problem is, when th...
pwenger by Level 3
  • 369 Views
  • 1 replies
I want to setup a working ENUM demo but not sure what I need. so far I have a CM6 and CUBE feature on my 2800. I presume I need to forward any SIP/ENUM type call to a sip proxy server to do the lookup and then forward that on to the correct device. D...
Hi UC experts,a hard one: When u are off-hook and a second call comes in normally your Cisco IP phone automatically highlights the second incoming call. To transfer the first call or to set it on hold you have to manually highlight it by pressing the...
Hi,CUCM 6.1 with MGCP on a 2851QSig trunk to Ericson MD110 switchCannot get caller name to work in outbound direction. It works inbound from PBX. Sends number only on outbound.Display IE is greyed out in configMy users have their alerting name config...
dear all,I have setup an inter-zone configuration on Gk, two gateways are rigestered with that GK, when i make call from IP phone on the first GW it goes all the way to the gatekeeper then to the other GW and the destination phone.the phone will ring...
