IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6030 Views
  • 14 replies
I am having a problem forwarding to an LD number in CCM 4.1.3. This only works when the caller is internal or within the same local area code as the forwarded phone.Anytime a caller from outside the area code calls in, and is forwarded to the LD num...
Hi all!I have an old MCS-server with 4.2. I want to byu new MCS-server and upgrade my CCM 4.2 to new hardware and new version UCM 5.1. What should I do to perform migration from old hardware and old CCM to new hardware and new UCM? Can you post step-...
paa by Level 1
  • 339 Views
  • 3 replies
Hi all, A customer plans to relocate a CUCM6.1 publisher to a new site with a new hardware and a new IP address. Hence, the IP address should be changed. According to replacing a single server or a cluster for CUCM 6, all subscribers should be rei...
I have a customer whose host site was affected by a tornado recently. The host site is pretty much flattened, and they are unable to get to the site to assess the damage. Anyway, they have a remote site that is in SRST, and the site is working fine, ...
