IP Telephony and Phones
Labels
Hi,I'm installing ccm5.0 and cisco 300 ip phones, my network consist of cisco 4503R and 9 cayalyst 3560 48 port.The problem that we face is as follows:when we unplug the ip phone from the switch and then plug it back it take about 5-7 mints to come u...
cinfazooo by Level 1
  • 298 Views
  • 1 replies
Question. We have 4 CUCM and 2 CME clusters. ALL CUCM's are interclusterd and CCME are H323 gateways. Configuration tested ok. Tested dialing and no issues. There is extensive overlap in dial patterns within these clusters. I came up with a wildcard ...
zawadzkij by Level 1
  • 258 Views
  • 1 replies
i have a strange question: after i build a cme system, i find all ip phone(cisco 7905)can not register to the cme router always, only reboot the router it can register, sometimes the start-config is empty! or the login password was changed! i opened ...
we have both the 7960 and 7961 phones. They are all in the same CM groups/dial groups etc, but the 7961's will not dial out. The 7960 dials out just fine. Is there a new firmware version for the 7961 on CUCM 6.0, or where would I fine that?
v-yelmene by Level 1
  • 457 Views
  • 3 replies
Hello, i have a problem to make this scenario work:PSTN call to phone whith CFA to another PSTN number. The call is not answer at all.I use a 1760 gateway connected through a SIP Trunk to CUCM 5.1(2).When i use H.323 connection, i have no problem. I ...
jtoque by Level 1
  • 880 Views
  • 3 replies
