IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6101 Views
  • 14 replies
We have one subscriber of the 4 sub in our cluster that has occasional high CPU and we go into Code Yellow. Started about a week ago. Happens about 10 times during the business day.All subs have about the same load with number of phones/gateways, s...
Hi all,Why my 7970G is displaying wrong time while all others are with the right time?I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.I've set the time-zone parameter on telephone-service.This issue is driving m...
rafael2gc by Level 1
  • 328 Views
  • 3 replies
hi we have a centralised setup of ccm 4.2(3) and the ip phones are in different cities,we also have a trunk to USA also.i have blocked offnet to offnet calls for the external transfer to PSTN.But as the PSTN line is connected to the central site gat...
kumar3880 by Level 1
  • 237 Views
  • 1 replies
hello, i have Cisco call manager connected to PBX via 2811 through VIC2-2BRI, the problem is sometimes the outgoing call does not pass and when i make trace, it displays what you will find in attachement.you will also find in attachement the confgiur...
dbenattou by Level 1
  • 357 Views
  • 3 replies
Hi,I need to configure AAR in one of the UC labs. I have a question here regarding the Dial prefix. There are two dial prefixes.One from this group another to this group.I am not sure whats the use of Prefix(to this group).For example I have two site...
Hi All,after doing thisStart > Run; type CCMPWDChangerwe were able to logon, and also to able to change the password, now even after restarting the whole server we can logon Start > Run; type CCMPWDChangerand we are not able to log on, but the appear...
reckhardt by Level 1
  • 282 Views
  • 1 replies
Customer has an old amp (McGohen MS-s1004) which connects today to an external transformers RCA connection on one end, and hard wired via analog pair to legacy PBX on the other end for paging purposes.So the question is can I run copper pair from FXS...
SBCdd7343 by Level 1
  • 489 Views
  • 5 replies
