IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hello guys,Are there any functionalities or features that Avaya phone system offers that Cisco CallManager can not? I am replacing an Avaya phone system with Cisco Unified solution and would like to know what are the features and functionalities that...
I have two voice gateways (2811 and VG224), both configured with MGCP. I am not using the "ccm-manager config server" command, to stop CM from configuring the gateway.I placed a fax call between both gateways, controlled with a CM 5.1(2)b. The fax ca...
lalo.rdz by Level 1
  • 312 Views
  • 1 replies
I have a gateway that can dial any area code with the exception of 502. When dialing 502 I get "The number you have dialed is not a working number" Below are the debugs from calling a non-working 502 number and a working 770 number. Worth noting that...
ahab by Level 1
  • 568 Views
  • 1 replies
I have a TAC case opened up already but things are moving slow so I wanted to put out some feelers. I have to clusters. One was an upgrade from 4.1(3) and one was a new 5.X install. Now they are both running 5.1(2). I have been noticing some stra...
shane.orr by Level 4
  • 472 Views
  • 5 replies
The ephones for VG224 don't get registered with SCCP on the gateway. I've already done the ATAs and the IP phones, and they seem working fine. I'm having some unluck with the VG224. I beleive the problem is from the VG224 itself. The config of this d...
valides007 by Level 1
  • 3410 Views
  • 10 replies
