IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5653 Views
  • 14 replies
Hi all,I have a client that has his IP Telephony solution running in Cisco CallManager 4.2. He has now purchased Cisco Unified Communications 5.1. I know there's is no direct upgrade from 4.2 to 5.1. So I'll have to rebuild the database to the new 5....
pmarques by Level 1
  • 374 Views
  • 5 replies
Resolved! PSTN numbers
Hi thanks for your previous responses it was helpful ,so i wanna know if it's possible with CME to group together some PSTN lines, let me explain; as example i have 4 PSTN's numbers or line each of them are connected to my FXO card and i want to setu...
Hi all, i have installed CCM 6.0 but i have problems with installing DHCP server. My CCM is on 192.168.150.0/24 network, 1.what should i enter on Subnet IP Address field. 2.Should the DHCP Subnet be from CCM 192.168.150/24 network or another. Thanx...
044102947 by Level 1
  • 526 Views
  • 1 replies
Whenever I dial into a phone or have the phone dial out it's always a one way conversation. I can never talk on the IP phone and have the other end hear it. The other end can always talk and it will come through the IP phone. The network topology ...
rraver by Level 1
  • 2088 Views
  • 16 replies
Pls anybody clear my doubts:- is the same local loop carrying voice call ,i.e. analog signal is used for carryng digital signal in ISDN implementation or different set of wiring is used to carry digital signal from customer site to CO.?
Unanswered Topics
