IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Hello, I'm consolidating two gateways at one office into one single gateway.Before, one handled DID calls. The other handled this office main number and just used a PLAR on the voice port to put the inbound call where it needed to go.Now however, I'...
snooter by Level 1
  • 331 Views
  • 3 replies
I have 7911G ip phone registered with CCM 4.1 and a power off occured and after the power is on the phone can not register only registeration process and there is no any menu key is active ,i tried to restore factory defaults by pressing # key and 12...
rajupawar by Level 1
  • 370 Views
  • 2 replies
Hi. I use a CME 4.2 and I need to set up that when the receptionist transfers a call to extention (this is working) and the person at the extention is not available (ringing for some time) the call will get back to the receptionist.Is this possible? ...
ualex by Level 1
  • 527 Views
  • 6 replies
Hey Guys...We've having problems loading our Corporate Directory. It takes several seconds (about 10) to load on our Cisco 7940 phones. The first three options show but the forth is blank with "Requesting..." in the status bar. If I go directly to th...
KeveyXXXX by Level 1
  • 331 Views
  • 2 replies
I have CME with 4 fxo linesI define an operator telephone with single buttonI forward call to fxo lines from outside with connection-plarvoice-port 0/0/0 connection plar opx 0!voice-port 0/0/1 connection plar opx 0!voice-port 0/0/2 connection plar op...
rsefer by Level 1
  • 449 Views
  • 1 replies
Resolved! IVR DTMF issues
Hi we are running c2600-ipvoice-mz.124-7f.bin on a 2651XM. This is a recent upgrade and it appears to have caused problems with IVR's being unable to recognise DTMF tones . Downgrading to the original c2600-is-mz.123-18.bin appears to have resolved t...
deep.blue by Level 1
  • 1462 Views
  • 5 replies
In CRS (v4.0), there's an IPCC Express configuration window with "secondary supervisors" and available supervisors" (where I can select/add a supervisor). My question is, I have an old user in the "available supervisor" window and would like to remo...
Hi.A couple of months ago I bought two 7911. The last week I try to register one of this phones against a SIP server but I dint know how to upgrade the image from SCCP to SIP. Someone know which files I need in my tftp to upgrade it?Thanks
