CDR Auto Generate
In CCM 4.1 is it possible to auto generate and then e-mail a user bill detailed report? I can see the e-mail and auto generate options for system type reports but cannot find anything on the user bill reports. Thanks
Hello,I have install nokia Intellisync client on E65 series and configure the sccp profile, with tftp server, but when I go to the callmanager to create a new phone, what type of phone should I chose?Is there any licence taha I have to put in callman...
We uses the Router 3640 NM-2V IOSVersion 11.3(10)T with 8 FXOs Voice daughter card Hardware revision 1.1 at HQ. We uses the Router 2610 IOSVersion 11.3(10)T with 2 FXSs Voice daughter card Hardware revision 1.1 at Branch.Calls each other work ...
Hi allwe upgraded our Callmanager from 3.3(4) to 4.2(3). On the old system we had MLA installed and some groups configured.After the upgrade I still have all the Functional Groops and all User Groups available. However I can not assign Privileges to ...
Hello, I'm actually configuring Fax off-Ramp on a Router 2811. It's working fine with an ISDN connection (Modulo 2 BRI), but it's not working with an analogic line(Modulo FXO) on the router, i have this message during the transfer, after approximativ...
HELP!!! I need to set up a remote 7960 phone to connect to our CME via a WAN. On the remote end there is a Linksys RV016 router, the phone has a NAT to a global IP address and the TFTP Server address set to the 7960 is the Gateway address of the 3825...
Does anyone know if the CME can display background images on the 7941/61 phones? I already have the 7970 background images working but would also like to have a grayscale version displayed.
Hello all, I've configured CME4.1 in a 2851 with CUE 2.3. I'm facing some issues with call forwards. Here's the scenario:Call-forward-All configured on IP Phone A to a external landline or handphone number-a) IP Phone B calling IP Phone A, call forwa...
Is there any way to set up Intercom so that it only works on internal extensions. Outside calls coming from the Auto Attendant should ring the line. I figure I may have to do it with two seperate lines, but was hoping I could use partitions or some...
Hi, What is Unified Mobile Communicator? Is it part of mobilitymanager? Thanks
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/srnd5_0/uc5_0/50dialpl.htm#wp1044323The following is quoted from the link above. I am not quite follow what it really means. Why force on-net calls dialed as PSTN? Design Guidelines f...
http://cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008064583a.htmlThe following is quoted from the above link. My question is1. How do I know that phone contains it already?2. How can we get the phone which co...
Dear pro,I use the CME 4.0(2) and i need to display the name of a specific called number; for example : if i call an ip phone from my GSM i need to see my name on the ip phone.So how can i do that.Thank you in advance
Does anyone know if this will still work if the PUB is down or is this a SQL change that would require the PUB to be up?
Hi all,I have just moved from CCME to CCM. In CCME to make calls from outlook all I did was install the tapi driver and enter the username, password and the address of the CCME box.I have installed the new tsp driver for call manager and entered all ...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
8 | |
7 | |
4 | |
4 | |
1 |
