IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hi Guru's I greatful if anyone can help me out.Actually i have a standard Cisco CCO account, were i dont have privilage to download Cisco updates and other CCM packages. So is there other way where i can get this downlods?BTW: Why Cisco don?t offer ...
cisco7912 by Level 1
  • 393 Views
  • 1 replies
Getting an error when adding 7961 to CCM (See attached document for error message). Recently added new CCM sr and new device pack. If I look under System > Device Defaults, no Phone Template options appear for 7961.CCM 4.0(2a) sr2cDevice Pack 46.4
Hi,i am using ccm4.1 with cisco3825 router for dialling out with E1 terminated in the router.i want to go for single analog connection circuit (not BRI or E1 or T1) only 1 line. Need help in getting the configs and voice ports required in cisco3825 r...
Helloi have some problems upgrading a 7960 sip phone , non call manager.it was working fine with 3.7.3 version and was registerred to some sip aerver until i decided to play with it and upgrade to P003-08-6-00.bin.i tried to follow this doc but i gue...
okenobi by Level 1
  • 452 Views
  • 2 replies
We are getting ready to implement a new CISCO VoIP system with CCM 5.0 and I have a question on directory number planning. The group of D-I-D numbers that is assigned to us begin with 08xx - 09xx. Not my first choice but what do you do. I don't wa...
Hello, I have problem with FAX Server I can Sending Faxes but I do not can Receive FAX.It appears to be FAX server Not negociate T.380x3956 11B9 0x46AF26EC 0/0/1:1.1 0/1:2 1130 g711ulaw 9000/1004R-2811-C#sh voice call sumPORT CODE...
We are running CCM 4.1(3) and have four VG248 analog gateways. I've noticed in the event logs of both our CCM's Transient Connections from 2 of the 4 VG248's every two seconds. In addition on the VG248's I'm seeing "Warning: SCCP 35: Registration fai...
tfelmly by Level 1
  • 592 Views
  • 5 replies
