IP Telephony and Phones
Labels
I have an issue with a 8845 that I am not able to select the ABC softkey (grayed out) , I would like to do a sipurl dial, however I don't see the options for CME 12.5 not running CUCM. Any help would be appreciated. 8845 running, load 8845 sip8845_65...
davec4351 by Level 1
  • 1145 Views
  • 1 replies
Hello,   I can not retrieve saved voicemail, new voice mails can be retried no problem    When attempting to play saved messages I get the error The message is not currently available   I have checked that critical services are started, I checked RTM...
galaga by Level 1
  • 2869 Views
  • 2 replies
I need to setup a hotline number. Any calls coming in on that number should route to the agents' Cisco phones based on their shift. For ex :Hotline number : 12345Agent1(77777) and Agent2(88888) will pick the calls in morning shiftAgent3(11111) and Ag...
Hi Team, I tried migrating a Cisco phone 7940 SCCP to SIP and shows me the following error: Migrate Phones - SCCP TO SIP Begin Time: 11/04/2016 12:31:05 End Time: 04/11/2016 12:31:05 Query: MIGRATE SCCP ALL PHONES SET Values: Reset phones = true Re...
Resolved! SIP Device Profile
Hello Everyone, Migrating 7000 SCCP Phones to SIP. Users are using Extension Mobility (EM) to log into phones. We have more than 5000 SCCP Device Profiles (EM). Do we need to migrate the DP to SIP as well or the SCCP DP will work with SIP Phones? Th...
