This one is killing me. I have around 70 SIP callboxes that register to ONE single voice register pool using "id network". They all have their own phone numbers. Like so: voice register pool 1id network 192.168.0.0 mask 255.255.248.0no digit coll...
For some reason, my 7941 phones (all are 7941) do not get the ringlist.xml file or the distintiveringlist.xml file. From what I can tell, my config is correct. tftp-server flash:Ringtones/Analog1.rawtftp-server flash:Ringtones/Analog2.rawtftp-serv...
Hello, We've upgraded our Cisco phones to new Cisco 8851 phonesets. The 5 buttons left of the screen are easily programmable, but I was hoping to program a few of the unused buttons on the right hand side of the screen. Does anyone know if these are...
HI I need some direction please im new into voip - ccnp routing and switching I’m looking for direction Does Cisco have a call manager that allows you to make calls via mobile phone using an application when connected to your corporate WiFi ...
hello please help me I have CUCM i need to configure PLAR with SCCP protocol i need also the number no a plar to call other phone thank you
I have an issue where a Cisco 8945 operating as a VPN phone, has no call history showing. Initially there was no TFTP set or alternate TFTP set. This was corrected but still there is no call history. When I browse to the phone all settings CUCM gr...
I tried to use the Cisco headsets 561/562 on Cisco IP phone type 8811 with the Y-cable. But they fail to work properly. Initial you get dial tone when activating the headset on the phone or audio when answering a call ut after about 10 seconds audio ...
Hi All, I just want to ask what could be the possible issue with our IP Phone. It is all of a sudden cannot make a call and cannot receive a call. when dialing, it is always on busy tone. nothing changes in the configuration. Sadly, the one handlin...
Need voicemail to email to not have .wav file attachment. Is there an option for Unity to deliver a link that will open a voicemail in the browser instead of the sound file itself
]I'm currently stuck between a rock and a hard place on deploying these new phones. We were using Meraki MC phones but since those were discontinued, we are switching to Cisco 7841 phones on Thursday. I had to recreate the phone menu systems from scr...
I have a single cluster environment running CUCM 11.5SU4 with a few thousand 8800 endpoints whether it be 8851, 8845, etc etc. All of a sudden with the last 2 sites we have deployed we have some phones at each site consistently having a 5 or 6 secon...
I have a user who is requesting the below functionality: Phone A (Internal VoIP or External)Phone B (Internal VoIP)Phone C (External) Phone B and C have different phone numbers. We're running CUCM version 10.5 Phone B is configured to forward all cal...
Hello, Can any one help me with the difference between Log partition vs Active partition vs Common partitionis there anything is missing out in this for disk usage please share your inputs
I'm facing the following problem,:When an incoming call to telephone A, it is possible for telephone B to capture the call.(PickUP Calls)Once the call is captured on telephone B, the display of telephone A shows the line "Forwarded to 27" where 27 th...
Hi AllCan anyone tell me how attendant console systems like ARC integrate into the call manager? do they log in as a user? does it take hold of lines etc?
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
Objet | Auteur | Envoyé |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
Utilisateur | Compte |
6 | |
3 | |
2 | |
1 | |
1 |
