450
Highlighted
Beginner
CME/CUE Redirected Call Rings on 2 Channels
Hi HetPro,
My CME v7.1 has a sip trunk to the PSTN. Incoming calls to 9701421 is translated to an AA pilot 7991. So the AA in CUE v3.0 prompts with a menu. When 1 is pressed, the call is transferred back to CME to a hunt-group pilot 991 that rings a couple of IP phone (with dual line ephone-dn) sequentially.
My problem is that there are always 2 calls presenting to a phone line: the first showing from 7991 and the second showing from the real PSTN caller number. When pickuping the handset, I hear nothing. Then using arrow key I can select to answer the second call. When the second call is finished, the first is still in held. I have to 'resume' it and 'endcall'. If I use ephone-dn single line, 7991 is presented as the clid, the send member in the group rings and can correctly answer the call.
If the PSTN call goes directly to the hunt group without going to CUE first, all work fine. Calls that end up in leaving  a message in voicmeail box are also working fine. Test dialing 7991 from a local IP phone is also working fine.
The cue is configured as below:
ccn subsystem sip
gateway address "10.216.1.254"
dtmf-relay rtp-nte
transfer-mode semi-attended
end subsystem
The CME is configured as below:
dial-peer voice 7999 voip
mailbox-selection orig-called-num
description ***voice mail***
destination-pattern 799.
redirect ip2ip
b2bua
voice-class sip outbound-proxy ipv4:10.216.1.253
session protocol sipv2
session target ipv4:10.216.1.253
incoming called-number 799.
dtmf-relay rtp-nte
codec g711ulaw
no vad
Any ideas?
Thanks in advance.
Larry
Everyone's tags (4)
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
