IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5717 Views
  • 14 replies
Hello community i am facing a strange problem that i didn't find an answer on it. the only thing i had found, that another user faced a similar situation but without got answer https://github.com/pjsip/pjproject/issues/2675  The problem when ISP send...
failed call.png telephone event 16000.png working call.png telephone event 8000.png
there is no CUBE between the telco and CUCM Could you provide some guidance on how to resolve this issue?* this call flow work on another telco.*Works for landline calls but not for mobile calls
1620415 by Level 1
  • 227 Views
  • 5 replies
