Hi,I am trying to do some policing on a 3650 and for some reason, the interface doesn't seem to want to apply my service policy. Here is my config: class-map match-any ExchangeClass match vlan 410 policy-map ExchangePolicy class ExchangeClass po...
Hi,While adding phone manually to cisco call manager I didn't have option to select SCCP.It's taking SIP by default after giving the MAC address, Is there option to enable to choice of protocol back.
So I am trying to come up with a way to mass deploy some 7925G wireless phones. We already have some in select locations, but we have to manually configure the network profile and then send them to sites. I’m trying to avoid having to manually config...
Hi all,We had a Cisco Call Manager version 4.3, upgraded to 8.6.2.On the other hand, we had some 7921G phones registered and working fine with firmware version 1.1.1.One of the 7921 broke down and we replaced it by a new one with firmware version 4.1...
Hi, We are using cisco 7925 wireless phones and though the phones gets registered with CUCM, it doesn't accept any calls. Also, the phone face intermittent registration problems. 2015-03-24 03:53:04:0610 CP-7925G user.crit netd: network down on...
hi mates, i have a 7975 desk phone and it has shared lines, when an incoming call comes in on line 2 and i pick up the handset and it automatically answers line 2 without me pressing the line 2 button.how do i disable that so i can manually press the...
I have problem in cme9.1 with 8 fxo it was working fine, Before one week incoming call drop after 3 min this is configuration for fxo supervisory disconnect dualtone mid-callno battery-reversalinput gain -3output attenuation -3echo-cancel coverage 32...
HI,I am running CUCM 8.0.3. We just updated part of our network and changed the DNS server. I need/want to verify if I need to rehost my license key. My belief is “NO”…From what I’ve read, when you change DNS, it changes the calculated value of the l...
Hi, I have a CME box connected to a CUE (running on ISM on the same router). Everything works fine so far, but I have a strange problem with the "call redirect" function in CUE: It´s only working when I´m calling the CUE script from an internal phon...
Hi, anybody in east SFO bay area ( livermore, tracy, Mtn house, Pleasanton) interested in sharing home lab for collaboration ? i have it almost ready and looking for a partner
Hi all,Is this command required to create the necessary config files for ip phones to register? create cnf-files I'm reading Jeremy's CCNA Voice and he doesn't have that command in his config file but his phones registered, mine doesn't.
My Name is Jerry Harris and I am having an issue with our mobile devices are showing status is unknown being the name of the sever the phone is registered to and IP address is unknown. Some of the devices register with the an IP address and name of t...
Hi,Is it possible to modify or delete the calling/display name in a SIP Header with cube (with a SIP Profile?) ?If yes, would you have a configuration example ?In this kink of invite, I would like to suppress or modify "Jack Shepherd"INVITE sip:+1206...
Hi, We have received few RMA replaced 7940 IP Phones and our CUCM version is 8.6. Am trying to register the phone, but all these phone says File Auth fail.I am not able to do the factory reset, no ITL or CTL file found. Erased network configs, but st...
Hello, I have created a cluster of CUCMs and 2 CUCM IM and Presence servers. Everything is based on IP address; I do not have any DNS configuration. But for Jabber and Webex, DNS configuration seems a must. So, I need to add DNS for CUCM and Presence...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
