Hi Dear Friendsi use cisco softphone. when operator answer for english press 1 for russian press 2. but i press 1 or 2 not work. how can i resolve it. sorry my english
Is there a way to automatically select Line 4 when dialing out on an 8851 phone registered to a CUCM 11.5? Or, is there a way to NOT select Line 1 automatically when calling out? Automatically Use Prime Line is disabled, and Revert to All Calls is...
In normal mode, all Incoming calls are going to the FXO using the connection plar voice-port 0/1/2trunk-group ALL-FXOcptone CAconnection plar opx immediate 112397caller-id enable dial-peer voice 5400 voipdescription FXO - Outgoing to CUCMdestination-...
Hi, Im trying to give DHCP to VOIP Phones, things work perfectly till i add more than 1 phone to each VLAN, then i get DHCP Conflicts at my Telephony router, wich gives DHCP to the Phones, then they enter a loop where they try to get an IP and a CM l...
Hi there!i am currently testing a Cisco 8851 phone with a 36 button KEM installed to it.when im manually configuring speed dials (by holding down a speed dial button on the kem for a few seconds) the speed dials are there and they work.Whats weird is...
HiWe have recently implemented CUBE on CSR1000v and configured SIP Trunk line. Inbound and outbound calls work properly, but inbound fax does not work. Our fax server is Issabel and I configured SIP Trunk between CUBE and Issabel. The PSTN supports ...
I am trying to use a CP-8865 with 8800 Key Expansion Module but the module does not power up.All the switchs we use are from Cisco.CUCM version: 11.5.1.13900-52 I use a phone button template with 11 lines: 10 for the phones + 1 to test the expansion....
Hello,Have jabber integrated with Unity Connections. When Jabber is first installed, user logs in using AD credentials. Voice and chat services are then up and running after login. However the voicemail is not but instead you need to click on the ...
I'm on CUCM 12.5.1, getting ready to update to 14.0.1. but I'm needing to search the system for any BLF appearances with a EXT. I've looked at dependency records and I'm missing something. is there a way to look these items up?
Hello..I have to ISDN E1 Interface on Cisco Router 2951, each E1 have a different phone number,, and i need to configure a 2 SIP trunk between router and 3CX system,, each phone number connected to a dedicated SIP trunk,, because each SIP trunk will ...
Is there any way customize the UI of Cisco jabber client or modify the look of it and is it possible to add the logo of my company
Hi I saw some threads on here about this same condition but could not find any that refer to Cisco SPA122 VOIP ATA. Is there some particular setting that could be causing this? It only cuts out when I call out, not when calls come in. thanks.
Hi All, Please help me solve this issue. I have to configure a cisco ISR 4321. But this routeur is no able to start. I got this error : Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00%WARNING: Resetting...Initi...
Jabber users are reporting that their smartphones (iPhone and Android) and becoming unregistered to CUCM after several minutes of no use. We are running v12.5.1 SU2. The users report they have not logged out of Jabber, but were using other apps and J...
How do i force a password change so i can log into this server?
Subject | Author | Posted |
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM | ||
04-28-2025 05:35 AM |
User | Count |
4 | |
3 | |
2 | |
1 | |
1 |
