IP Telephony and Phones
Labels
Hi Everyone,I'm having a problem with the no answer forward to AIM CUE voicemail. I'm running call manager express 8 with unity express 7 on a 2851 with an aim-cue. I can call in and get the auto attendant or dial right into voicemail with my cell ph...
Hello,A cluster with five CUCM servers do backup to a windows server using freeftpd. Then, after adding CIUS support using a device packcage backup fails from some of the cluster servers, but others work.I have readed and seems there are a more than ...
mcecilia by Level 1
  • 1152 Views
  • 2 replies
Hello everyone,I wanted to confirm that if I am running 8.5 and want to go to 8.6 I can download that upgrade for Cisco.com and not have to order any software through the PUT or anything else correct?Thanks in advance.  All replies rated.            ...
Use 2 line phones: 1-line Primary DID DN,  2-line ACD DN for UCCX agent calls.Typically our agents(7940 phones) pick up the handset and select the second ACD DN to connect to queued calls. The 9951 phones won't allow me to answer the second DN after ...
