IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5959 Views
  • 14 replies
I have read many of the posts on this topic but cannot seem to find the answer to my problem.  I can't make conference calls with anyone outside of the building.  Internally I have no problems.  We upgraded our router to ver. 15.0-1 and call manager ...
hi Guys,i have cucm 7, & installed sipdroid on my samsung galaxy S.my user/dn config in cucm is as belowusername(from ldap): abc@abc.comDN: 11111Digest Credentials: 22222pincode: 33333i applied on sipdroid as per above credentials as belowAuthorizati...
Is there a design document that shows what files, and their size, that  are added to Flash.  I need to add audio files and phone background images and wnat to make sure I have enough flash, to support CME and the additional images and audio files.
dvaggalis by Level 1
  • 375 Views
  • 0 replies
Hi,I am trying to take backup of UCCX 7.X server on a PC in the network. I can ping that PC from UCCX server. I have shared a floder in that PC with read/write permission.When i am trying to update backup storage location from UCCX 7.X server itself....
Resolved! ISDN Setup message
UCM version 7.1.3.10000-112811 configured as an H.323 gateway running 12.4(13r)T.I have one user that is having difficulty dialing numbers.  This happens at random and he is the only one that has reported the issue.  The symptoms are he dials a long ...
CCM 5.1.2 backup is failing.  Scheduled backups to another network directory have no error message or history, it is blank as if it doesn't run.  Manual backups receive the following error message "Unable to create backup storage directory: /common/d...
Resolved! C7962G and CCM 4.1
Good day, all -I'm hoping for an easy resolution...We've just bought a CP-7962G phone, but CCM 4.1 does not recognize it. I understand I need to install the firmware for this phone in the TFTP directory, but I've been unable to unearth a task-specifi...
