IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5808 Views
  • 14 replies
hi, I am new to this so please bear with me. We currently have a satellite office setup with an mgcp gateway where the pri is located at our main office. We want to add srst capabilities to this gateway which means I need an analog line ran to the...
linda0055 by Level 1
  • 534 Views
  • 7 replies
We currently have Bogen and Valcom paging amplifiers connected to our Nortel Option 11. We would like to move this paging gear over to a Cisco 2811 Gateway/CUCM 4.1(3). How do I determine what type of VWIC is required in the gateway to support this...
mlitka by Level 2
  • 9079 Views
  • 22 replies
I am running CUCM 4.2(3)sr4b, latest software for 7962 SCCP phone and 7915 expansion modules. When I go to configure the phone button template, it only gives me the option to configure 34 lines, 6 on the base phone and 28 on the expansion module. A...
Resolved! AXL log on
We are looking at 3 applications which require a AXL log on , all three apps will potentially make use of their own log on at the same time- we are evaluating the type of app from different vendors- Does any one have experience or know if any issue w...
iptuser55 by Level 6
  • 457 Views
  • 4 replies
Hi All, I've setup MTP IOS in CUCM for MGCP T.38 faxing which is required for inbound faxing for Exchange 2007. then create two MRG, one has IOS MTP and the other one has CUCM MTP. then create MRGL that has MRG (with MTP IOS) and MRG (CUCM MRG) respe...
