IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6133 Views
  • 14 replies
In Cisco Call Manager Serviceability, I can monitor “calls in progress” under “Call Process” “ Call Activity” which appears to show current number of calls in progress at a given time.I am attempting to locate a way in which this informat...
Our company wants to push out a speed dial (new conference bridge number) for all existing Cisco phones. Without exporting the phones, editing the .csv and importing them back, does anyone know of a way to do this? (Two clusters: 6.1.2 & 4.1.3).
Hi, I have very limited info but I'm looking to point someone in the right direction. My colleague has the following setup in Europe. Cisco Call Manager version 7.1 with ISDN trunks to the PSTN. The Call Manager has SIP trunks to an Aspect Call Ce...
voip7372 by Level 4
  • 2120 Views
  • 2 replies
Hi,CUBE is installed between CUCM and Carrier SIP Trunk and want to the firewall feature requirement in case the firewall install in front of CUBE to protect from Carrier.If the firewall is Cisco ASA, I can enable "inspect sip" to inspect the payload...
cjrchoi11 by Level 1
  • 971 Views
  • 0 replies
