IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5845 Views
  • 14 replies
Would like to know the details of the below debug.  I would like to know why we see multiple entries when there is an incoming call in our debug detail.  Is there some kind error on the configuration? I just want to understand what is happening in th...
towertech by Level 1
  • 337 Views
  • 1 replies
DearsI was proposing a Cisco IP Phones 6800 series, hence these IP phones are not supported on CUCM 12.X, hence it is in datasheet it is mentioned as a multiplatform ip phone , can anybody explain me where i can use these IP phones  Thanks
adamgibs7 by Level 6
  • 1341 Views
  • 5 replies
We have purchased the Enhanced to CUWL migration SKU  (MIGE-UWL-12X-STD) How do you go about getting the CUWL licenses fullfilled to the SmartAccount? All the Expressway and other licenses where fulfilled but the CUWL licenses did not populate.
edotson by Level 4
  • 448 Views
  • 1 replies
Recently we have started to have an issue with 7841/8841 phones. When a user goes to access their voicemail, the phone acts as if it does not take the users input and keeps repeating "Enter your PIN and then press pound" after each input. I'm under t...
klasko16 by Level 1
  • 498 Views
  • 2 replies
Hi everyone, So I have a rather weird issue with this phone. It's configured to use ethernet which was working fine. I have an asterisk server it connects to which was working great. Recently it starts to drop the ethernet connection. I try to ping t...
trinidad by Level 1
  • 427 Views
  • 1 replies
Hi, I have a Cisco 8841 that will not startup, it does power on, it would go into the normal boot process, then when it gets near the end, it would make a weird color on the screen, then reboots, it would do it over and over again, I am not sure what...
Ian Sully by Level 1
  • 538 Views
  • 1 replies
What would it take for a cisco VOIP phone from the office to be used at home? How complex  configuration wise and expensive would it be to offer that ability to a small number of staff? I know other companies do it so I know it's an option but not su...
JMCNEL by Level 4
  • 1721 Views
  • 5 replies
