IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5649 Views
  • 14 replies
Hi I have 9.911 and 911 setup as route patterns with urgent priority and I have used predot only at the route list/route groups not at the route patterns. My question is how will 911 route with the predot specified at the route list/route group level...
John Tan by Level 1
  • 863 Views
  • 1 replies
We have five 7921 phones. There is no problem if you keep using them , but all of them would lock up if you don't use for a while, for example 3 or 4 hours. We see all 7921 phones are dead every morning(beacuse nobody uses them in the evening). When ...
We run a Call Manager cluster with centralized call processing. Branch offices (connected via T1) are currently in the same city and have the phones at the branch offices register to the centralized CCM cluster over the T1. This works great.We are ...
Hi all,I got an issue with RTMT for a sub that sits across the wan to another location. Phones and gateways are registered fine with the remote sub but when I opened RTMT, the counter for CM heartbeat is "0", as well as phone registered counter, gate...
bluejays by Level 1
  • 336 Views
  • 4 replies
