IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5808 Views
  • 14 replies
Hello,a customer has a centralized CM 6.1 install with branch offices all over the state. All outbound calls at the branches go out a local H.323 gateway. For D/R purposes wenever the branches PSTN connections are down we want to route calls automa...
Hi,I just want to ask if this is possible. What we are using right now is Avaya and we want to eliminate or lessen the tie-trunks between sites. Is it possible to connect the Avaya switch to a Cisco router then Cisco will convert the voice traffic in...
jpl861 by Level 4
  • 281 Views
  • 2 replies
Hello, We use Multicast MoH with SRST. After change the MoH File from the Default CCM AudioSample(3Mb) to the client MoH File(40MB), the MoH with this new file did not work, on the Debug ephone MoH a message telling that file could not be open ...
I am in the process of provisioning a system from a customer and got an interesting request. Here is the scenario:An employee has 1 DID phone number. If that number is dialed, somehow the system knows if it is a phone call (rings the phone) or a fa...
