IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5804 Views
  • 14 replies
I am looking for some ideas on how to implement the following,We have a call handler with the main greeting that allows caller input, by pressing 0, the caller is routed to the Operator. Base on the time of day we want to route the caller to three di...
hii'm building an ipccx script, and stuck in one step, this is a brief description on this step:i want to prompt the caller to enter some digits and i want these digits to appear on the CAD desktop once the caller is connected to this agent...i don't...
I'll do my best to try and explain what is happening...The customer started out with a 7920 as a member of a hunt-group, along with a few other extension.The 7920 went bad and they decided to replace. They moved the ephone-dn to the replacement 7920...
m-ketchum by Level 1
  • 307 Views
  • 4 replies
Guys,IS there a specific requirement that the prompts recorded in CUE 2.2 Auto-Attendant script have to be in the format - " G.711 u-law, 8 kHz, 8 bit, Mono" ? If so, is there any specific recording software which can create this sort of .wav file? I...
Hi,I have 3 PRA circuits installed on one 3845 router. I want to send calls from certain numbers out to a specific PRA. Following the Cisco doc, I used answer-address command to match the calling number, then trigger a translation-profile that prefix...
Chuan Liu by Level 1
  • 1036 Views
  • 11 replies
