IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6045 Views
  • 14 replies
I have a CM6.1 system. Is Feature Access Codes supported for CM6.1 other than for Mobility?I use Live Record and currently I have to Press "conf" + Live record route point + "conf" - this is a 3 button option. I am trying to make this a 1 button func...
joel by Level 1
  • 327 Views
  • 1 replies
Hi i have next sheme CCM6.1 -> 2821 with vic2/4fxo and em-hda-6fxo-> PBX -> pstn.All incoming call goto over vic2/4fxo on ip phone. Then secretary transfer call on pbx over em-hda-6 fxo and subscriber end call to hang up the receiver. Port on vic2/4f...
Resolved! FXO Paging Advise
I don't know much about the interacy's of analog/paging, so need some guidance. A customer has an existing PBX system with paging setup. They have to self-amplified speakers that connect to an external valcom power supply. They are putting in a ne...
II was curious is there was a utility with the likeness of the dblhelper from version 4.x? I thought that was a quick and dirty way to see the health of your DB. I know that version 5.X does not use SQL...If not, what is the best way to determine t...
cplatt01 by Level 1
  • 327 Views
  • 2 replies
Is it possible to register two CUCM to one gatekeeper and properly route calls between them. CUCM 4.3 ---> GATEKEEPER <----- CUCM 6.0CONFIG: gatekeeper zone local Cisco2811_GK1 cisco.com 172.24.1.250 zone local Cisco2811_GK2 cisco.com zone prefix Cis...
dmckelvey by Level 1
  • 274 Views
  • 1 replies
