IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6065 Views
  • 14 replies
I have a customer whose host site was affected by a tornado recently. The host site is pretty much flattened, and they are unable to get to the site to assess the damage. Anyway, they have a remote site that is in SRST, and the site is working fine, ...
Resolved! CME DN Gets Hung
My CCME often has one or two DN get hung. No tones come out of the phone. I tried to remove the DN but got the message: 'DN 2 has active call on interface 50/0/2 CH1.Cannot unconfigure'. My only solution is to reload the CCME. Do you have any better ...
Chuan Liu by Level 1
  • 553 Views
  • 6 replies
I have configured my UC520 in hybrid mode with some phone having buttons for DNs configured as trunks and other phones having to dial "9" to get a line. With this setup if an phone configured with a trunk DN picks up the line all other ephones using...
tato386 by Level 6
  • 253 Views
  • 2 replies
I have a site in rural Kentucky that is serviced by copper DIDs. In the past, inbound calls via the DID trunks were delivered correctly to each telephone AND if unanswered would rollover to Unity. Today, the calls ring the appropriate phones but th...
fultont by Level 1
  • 572 Views
  • 8 replies
HiThis is a new config to move from SRST to CME-as-SRST (c3825-adventerprisek9-mz.124-15.T4). I want the following done when router falls back to CME-as-SRST mode. I already setup the configs but we will test. I need a sanity check to see if this wor...
aamercado by Level 4
  • 520 Views
  • 2 replies
I have a 2811 with PRI running SRST.My telephone number range is 555-389-0800. I am recieving all 10 digits from telco, and am using 5 digit extensions. Since the first digit is a 9, I created a translations pattern in CCM so that extensions are 80...
Hi a strage problem. I have a SIP phone behind 1812 configured for VPN to central office (PIX 7.2). This phone registers and can commincate with central office very neatly. When this phone calls another SIP phone behind one more VPN (using 5505 or st...
shrutid22 by Level 1
  • 539 Views
  • 1 replies
