IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1222 Views
  • 6 replies
Hi All,Could it be possible to use my 7204VXR router for routing calls from Avaya Definity phone system between our intranet connections on an E1 pipe?I will be going to connect my 7204VXR router to the DS1 board of my Avaya Definity,our intranet end...
capajaron by Beginner
  • 276 Views
  • 5 replies
Hi Guys,I have a problem where by i have an analouge phone hanging off a VG248 - all working fine, except this phone is a nurse call phone and requires a certain voltage running down the line. Can anyway give me the line specifications that the VG248...
I have central call processing, 2 offices, each with their own GWs.I am having trouble with international calls from one of the offices (Office A). My international Route Pattern (INT_RP)in CM is simply a 9.@ for Office A. For Office B (INT_RPB)it ...
mparella by Beginner
  • 523 Views
  • 24 replies
hi We have a CUCM 6.0 setup with 2811 router as the voice gateway.I have configured it for SRST also.I have made the necessary changes in the CUCM.I am able to view th SRST Ip address in the Ip Phone also. But when i try to create a ACl in the...
kumar3880 by Beginner
  • 188 Views
  • 2 replies
Hi,I have set up a CCME and l am having some problems with 7910 phones trying to register to the CME. They can get an IP Address via the DHCP and everything else looks OK, apart from the Call Managers they are homed to. Is there a way to factory defa...
2 users were on calls. Both users had dead silence on their calls at the same time, and at least one of the phones said CM unavailable, features disabled. The call came back momentarily, then there was silence again. Hung up the receiver and the p...
awaggoner by Beginner
  • 674 Views
  • 3 replies
Resolved! PRI Cutover advise
Hello,I have been tasked with handling a PRI cutover (we are getting rid of legacy PBX and going with a callmanager solution (with 2811 router with Vic2-2mft T1. I have minimal experience with routers/switches.I understand how to configure the T1 for...
I upload a wav file with the next format:16-bit PCM ,Stereo and sample rates of 48kHz in the section "Music On Hold Server Audio Sources", and select this file in the fields "User Hold MOH Audio Source" and "Network Hold MOH Audio Source" in the pho...
