IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1183 Views
  • 6 replies
Hi,CME voice gateway 2811 has VIC-4FXS/DID configured as DID trunk. The local teleco said they send us 4 digits, however,we only received the first digit instead of 4-digit for inbound DID calls.IOS version is 12.4(15)T3.signal type is wink-start.Can...
jjia by Explorer
  • 558 Views
  • 5 replies
I am running CCM 4.2. I have a facility that uses a 2820 (h323) for outbound cals through a T1. When calls are placed, the router sees the call but it takes 10 seconds before the call rings out. During this time the IP phone says "call proceed. This ...
ahab by Beginner
  • 313 Views
  • 3 replies
Does anyone have experience with configuring a single fixed audio source (live stream? The guide is not intuitive enough and currently all users have is silence when placed on hold. The stream is a radio station (company owned). We also cannot tell...
rudyfaber by Beginner
  • 537 Views
  • 9 replies
Hi,We need to telnet to one of the phones to monitor some traffic but we can't telnet to it (192.168.3.53), whenever we try we get the response:C:\>telnet 192.168.3.53Connecting To 192.168.3.53...Could not open connection to the host, on port 23:Conn...
Hi,I am having a problem with B-ACD Moh. What happens....when i call in, i get the CUE-AA (thanks for callinn....press 2 for Customer Service) when i press 2 it goes to the B-ACD hunt group and listed extentions ring 1 after another. if no one picks ...
Hello,I planning to have 10 digit extensions in CUCM I want the users to be able to dial both 10 digit or just last 4 digits of their numbers to call each other? How can this be done, since all the translation rules refer to external calling and not ...
FAX's connected to VG224 receive line error on incoming FAX's. Outbouond FAX's complete successfully. This is an MGCP gateway I will include the MGCP config in this postccm-manager fallback-mgcp ccm-manager redundant-host "Call Manager Publisher"cc...
mgrimes by Beginner
  • 401 Views
  • 2 replies
