IP Telephony and Phones
Labels
Hi AllI'm having trouble with a translation rules.I created the following rules :voice translation-rule 1 rule 1 /^8/ //!voice translation-rule 1111!voice translation-rule 1112 rule 1 /^9/ //!voice translation-rule 1113 rule 1 /^8/ //!voice translati...
Hello Everyone,I am integrating an Avaya G3 in Honduras with a CCM 5.1 in Canada (HQ)using a Cisco 2821 router. After completing the integration, would it be possible to do smart routing? What I mean is if a user in Honduras wants to call to US, woul...
On the 7961 IP phone, Login & Logout Extension mobility displays after pressing the services button. But when I press either option, it displays ?Host not found?.Hi,I tried configuring Extension Mobility on Callmanager 5.0 on 7961 & 7940 IP phones. O...
When setting up our new ISDN-PRI service with the UC520-48U-T/E/I-K9, outgoing calls cannot go through, but receive incoming DID calls no problem.I know its a PSTN setup issue, but do not know how to fix it.Any suggestions?
We use CCM 6.0.1 and UC 2.0.1We have a phone that receives calls from other phones when that caller is calling another number. The phone acts like an operator number which it is not. Is there somethng in Call Manager I can check to see why this phone...
Mojo1 by Level 1
  • 445 Views
  • 3 replies
What is the cheapest and easiest way to listen in on a phone call from another phone? We have a telerecruitment facility and the supervisors would like the ability to listen in on calls being made for training purposes.
I have a need to make restrict a Ephone from Dialing out. I'veimplemented the below config. But it doesnt seem to work.!voice translation-rule 10 rule 2 reject /9../ rule 3 reject /9......../!voice translation-profile LOBBY translate called 10!ephone...
jcounter by Level 1
  • 656 Views
  • 5 replies
