IP Telephony and Phones
Labels
Please let me know if this is the wrong area for this question...I setup a Cisco VPN client to our office. Down this tunnel I use the Avaya Phone Manager software to run voice through, which worked just fine for months. The phone system is an IP Offi...
We are installing a two site UCM Business Edition solution. Main site single gateway will be setup as h323 gateway (due to need to run T.37/tcl scripts - to get faxes to emails).We also have a vg224 at main site that will have faxes, modem and polyc...
Hello,I have some problems with my Cisco VoIP system. I use a VG224 gateway to connect 24 analog phones to the VoIP net. On this Gateway the MGCP service is running and is connected/registered with the Communication Manager 5.1(1).Everything is worki...
sgvoip001 by Level 1
  • 1228 Views
  • 5 replies
Is it possible to impliment CCM based CAC with a single gateway?In our scenario we have a single h323 gateway that has a PRI to the PSTN, and a T1 to a frame network. The other end of the frame-network is a partner CME router (which we don't control...
Hi all,I am trying to register my Phone (Nokia N95) with our CCME router. have anyone successfully set up this phone with CCME?I have configured SIP on my CCME but it seems that there is a problem since I am getting some errors when I try to register...
A call manager server has just under 100MB of free space on the active & inactive partitions on both the Pub and Sub, CDR has been disabled and a manual purge performed (made no difference),tracing is at default settings and still unsure why utilizat...
heathrw by Level 4
  • 1295 Views
  • 1 replies
