IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5879 Views
  • 14 replies
Resolved! VG224 IOS upgrade
I am planning to upgrade the VG224 to Version 15.1.4M10(MD) and I am confused which IOS below I need to download. The current IOS version of the VG224 is 12.4(22)T5. (flash:vg20x-ipvoice-mz.124-22.T5.bin). Can anyone explain me the difference of two ...
Hello all, I have a customer wanting to migrate some 7941 from SCCP to SIP.In bulk i created the Phone Template and tested the migration. The phone linked to a "classic" ethernet port.However, this customer has dot1x enabled on every switches interfa...
Dear Friends      I had a cisco router 2951 with cme 10.5 installed. I want to use this router as sip and sccp phone service everything is ok, but I had one problem that I had a voip gsm gateway (4 sim cards) and I don't know how make configuration t...
Hello Community,we switched from our PBX to SIP Trunk. We have a CISCO 29series (without CUBE). The router interface is directly connected to the Internet with a public IP address. Unfortunate we cannot register our SIP Trunk to the ISP. What did I w...
Hello,I use a Cisco SPA112 VOIP box, connected in Ethernet, on a router for several years for my phone line.I would like to move my phone away from my router (I will not be able to use a long ethernet cable) and connect the SPA112 with a WIFI Etherne...
I am use ProTech voice gateway integrate to our cucm ver 11.5. Now the outgoing call from cucm to mobile through voice gateway successfully done.  We just add the sip trunk with route Pattern and non security profile. The issue in the incoming call f...
OmarMa_90 by Level 1
  • 311 Views
  • 1 replies
