IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Hello Folks,We moved into a new office and all DID blocs are switched into the new PRI in the new location. The problem is when I call 911 they still see the number coming from the old address. I called the carrier in order to have them to update thi...
Hi,I have a router which looses layer 3 binding when the it's powered down. I have put this command "mgcp ip qos dscp ef signaling" in solving the problem to no vail. I have to re do configs for evry power failure I experience. What else can I do ?
sithellp by Level 1
  • 386 Views
  • 3 replies
Guys,im setting up a paging app and having a little issue with multicast. we have two locations connected viaFibre. head office is working properly but im not getting any multicast traffic to the remote location. the remote location is receiving text...
a.gooding by Level 5
  • 332 Views
  • 2 replies
using CM 4.1IPCC 4.04.If the IPCC server was to lose power all the CTI RP would unregister. is there a way I can forward these calls to unity in this state (with out upgrading to CM 4.2)Thanks
In a default CME configuration, I see that G.711 payload is being used for the RTP traffic but I'm also seeing in the Skinny StartMediaTransmission message a G723 Bitrate: MEdia_G723BRate_6_4 as well and don't understand what that is. Can someone ex...
kaolee by Level 1
  • 527 Views
  • 1 replies
here is the scenario. I have 3 analog pots lines for inbound and outbound calling. Two of the pots are in a hunt group from the carrier so they ring staff member phones via a plar. the other rings only the ceo. so far so good.now what they want to ha...
whanson by Level 2
  • 306 Views
  • 2 replies
