IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
I understand that when deploying a CCM cluster the Publisher must built first.Does it also have to be attached to the network before commencing with Subsciber build?. Cannnot seem to find the document at the momment expaining the prerequisites and pr...
Hi, I'm having a bit of trouble here with the port speed on a few phones. It doesn't seem to matter which type of phone I use, 7911 or 7941. I have any area, All on the same VLAN, All points going to the same switch. When I connect a phone through...
dmcavinue by Level 1
  • 289 Views
  • 1 replies
Hi all, I cant for the life of me get my fax solution to work I brought a VIC2-2FSX and want to have two fax machines off of it. Does anyone have a config already configured I can look at. I seem to get one thing sorted then another thing breaks. Exs...
Hi, Suddenly around some 20 ip phone display showing temp fail message while on call for a minute.Then i checked the logs and event logs,found that there is no gateway rehoming and reset.But in the event log one error showing that Sdl link out serv...
gnanesh.m by Level 1
  • 738 Views
  • 2 replies
Hi,i have two cases:1) When i am trying FAC with a FAX it does work it just gives a fast busy2) When calling a number than a fax is on an extension it does not work, only when i call a direct fax it works.i have CCM413 and H323 gateway.VG224 is used ...
twissam by Level 1
  • 475 Views
  • 3 replies
