I want to add Background images to my 7941 and 7961 phones how do you do this on cm version 5.1
The administration guide states clearly that FAC features work with all Cisco IP Phone models and MGCP-controlled analog gateway. I would wonder that FAC features work with digital gateway on PRI connection or not?
hi...how ip phone make trunk with switch port? does the switch at least need dynamic mode(auto,desirable,...). some doc said that we dont need explicitly configure switchport to be trunk.. does it mean dynamic port(auto,desirable,..) is enough which ...
Dear all,How to configure meet-me conference using Callmanager express and Unity express?Thanks.
Guys,I know CCM and Unity has a very stricted for 3-party software and hardware.Can I enable iLO at MCS7835 for CCM and Unity??Ken
I have noticed that in my environment, all of my 7912s have ping times of around 65ms, where as my 7940/60s are around 1ms. They are using the same VLAN and even reside of the same switches. Is this normal??
I currently have the 7940 IP phone sets and unfortunately my business is located in a poor location to allow us to sustain our phones via the internet. I was wondering if the 7940 phones can be converted to be used with a tradional T-1 phone line. ...
-2851 12.4(11)T1-CME 4.0(2)-7941g firmware 8.2.2SR1when I dial to 7941g IP phone, shows properly the caller information during ring but not shows the '1 missed call' on the target IP phone's LCD panel after hang up the originator. also not shows on t...
Hi,I have a CCM running with 4.2(1) sr1b and 7911G, 7941G and 7961G. For the 7911G I have the option to see the "View the User Guide for your phone" option on the CCMUser page. For the 7941G and 7961G that's not visible. I'm using a locale other than...
If I understand it correctly CCM 4.2 can not be upgraded to 5.x. Is that correct? Do I have any options?
Hey Guys,First time on netpro. Looks great. I have vg248, 7845 MCS, ipvc3540 to identify which serial #'s are where? I dont have pyshcal access to the equipment. is there a way to get the serial number on the above mentioned devices. much appreciatio...
One of our servers are configured to use same DN but different partition. For example, ext. 101 in Partition A is assigned to a phone and ext. 101 in Partition B is assigned to the Device Profile, is there a problem w/ this?Also, when I create a Unit...
I have a CEO and his assistant. The CEO is on the phone and a second call comes in and the assistant answers. Now, she wants a way to see if the CEO is still on the first call or available for the second call. Is there a configuration or application ...
Parked calls are being lost when other call comes in.
Hi,I've recently installed multidirectory.asp and am attempting to point to 2 clusters running DC Directory.I created a new service and from an IPC subscribed to the service, I get the 1) All Directory Sear2) Cluster-1 Directory3) Cluster-3 Directory...
| Subject | Author | Posted |
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
