IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5599 Views
  • 14 replies
I am running CME 4.0.3 on a 2811. I am having problems getting the local directory option to show via the 7961 phone. It just gives "host not found" message, all other services on the system are working fine. Any ideas?
neilo by Level 1
  • 4623 Views
  • 1 replies
  • 5 Helpful votes
Hi,Does anyone specifically know whether there is a firmware parameter required for CIPC ("load" command) when running it with CCME? I have doen a fair bit of digging and all I can see so far is that you can specify the phone type as "type cipc".I un...
cjhunt by Level 1
  • 3999 Views
  • 9 replies
CER 1.2(3a)Ssr2aOS 2000.2.7Sr8While reading through a field notice for DST fix for CER it states "For CER version 1.2(3), please apply OS 2000.4.2SR14 which can also be downloaded from the link above. These Operating Systems contain the fix for the D...
So with the announcement of 6.0 I am worried about deploying 4.x and having to upgrade in the not so distant future. Have people been deploying 5.x successfully? Does anyone know when 5.x or even 6 (when it is official) will be golden bridge?Take i...
jlefko by Level 1
  • 274 Views
  • 2 replies
Once a VPIM integration is complete, should the CSVPIMConnector service be started and set to automatic ?My current VPIM integration seems to work properly once this service is started. The default setting is to start the service manually. Should th...
I am presently on Call Manager 4.1 with all my Gateways running MGCP. I would like to switch to H.323 for the caller ID and T.37 protocols. However, as the Cisco Documentation states, FAC is not supported on an H.323 gateway because the gateway does ...
phrodide by Level 1
  • 511 Views
  • 2 replies
Will be implementing an emergency responder for a new customer. They are in one building on multiple floors. All 911 calls will go out to the same PSAP. Everyone will have a DID number.Should the individula DID numbers be used for the ELIN's or woul...
rvincent by Level 1
  • 622 Views
  • 8 replies
