IP Telephony and Phones
Labels
Dear All, This is the first time I am going to add 100 DLUs in CUCM version 8.5.1, and I have got .lic file to upload. I am seeking your help to know if there are any precautionary steps to be taken and any services to be restarted after upload. Than...
Syed by Level 3
  • 295 Views
  • 3 replies
Hi, We have a CUCM 11.0.1.20000-2 and I need to install a device pack to enable a new phone. So I downloaded the latest device pack 11.0(1.22049) When I try to install this devicepack I get an error: A valid upgrade file must be provided before an up...
Hello. I'm looking for solution to setting up RTMT custom monitoring for FXO port used on 911 POTS lines? I looked at it and there looked to be 2 types ways to check an FXO port. One was the port status and I think your outputs were 0, 1, or 2. The ...
Hello all We have some 7841 phones registered with CME. but missed calls, recent calls are not showing. when I press settings button and selected recent menu, nothing happens.  phone firmware is 78xx.11-0-1-11.  voice router firmware is SPA.156-2.T.b...
I did below procedure: Start with the phone in a powered off state.While holding the "#" key down on the keypad, apply power to the phone.Keep the "#" key depressed until you see the LEDs on the phone begin a 'walking' sequence, where they walk down ...
ASHAISAB1 by Level 1
  • 279 Views
  • 2 replies
Hi, I am using same number for two phones. For first number it will be primary line and for the second phone it will be secondary line only to make international calls. I want to configure in such a way that whenever incoming call comes on that numb...
Hi everyone, Looking over the User guide for PLM 11.5: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/11_5_1/userguide/CPLM_BK_CE0970F4_00_user-guide-rel-1151/CPLM_BK_CE0970F4_00_user-guide-rel-1151_chapter_00.html) the guide reads tha...
Nadav by Level 7
  • 399 Views
  • 0 replies
