IP Telephony and Phones
watch here Journey banner_1
Labels
Hello,We have CUCM  8.6.2.22900-9 connected with Lync via sip trunk.Our calls traverse fine but there is one trunk which is giving us issue.when we dial into lync conference and put in conference ID , it says, conference not found. The same Id used a...
kbeelwar by Level 1
  • 1915 Views
  • 6 replies
Hi All, I'm getting the error as "CallManager - InitializationState: The Call Manager service has not fully initialized". When i checked the services are all up and running fine.  I'm using the CUCM version 8.5.1.10000-26.  What does that alert mean....
Hello,I developed a VXMl application few months ago and it works well, but now it doesn?t work fine (I don?t know if the IOS version in the router has been change or if there was a change on a dial-peer (I think not).the problem is that now in a dtmf...
Dear allI have Product Authorization Key For 2901 i provide a file.lic from cisco portal but after that I realized that the file is corrupted i made mistake i used Product Name instead PID after that i try to use the rehost on portal cisco also i got...
We just got a batch of new 7821 IP phones in and I cannot seem to get them to register with our CUCM (8.6.2.20000-2).  I've added dozens of 79XX series phones in the past without this kind of problem, granted those were SCCP not SIP.  The phones get ...
Hi Community, i experience a somehow strange problem.I configured a phone button template which is used without any problems as desired when EM user is logged out of the 8961, all seems nice.But when the user is LOGGED IN successfully the PBT gets ig...
Hello, I am trying to add licenses to CUCM 7.1(5) through UCL. In recent discussion blogs, I see that I can use part codes for up to CUCM 8.6 and it will give me the required licenses (Because till CUCM 8.6, it's still DLUs in the backend. I am using...
