IP Telephony and Phones
Labels
Hello,         I had CUCM 9.1 PUB and SUB. Now the Publisher is not working anymore due to hardware issue on the server. Now I need to install the Pub and join it to the subscriber. How do I do that any documentation will be helpful. I dont have back...
hi,what is the difference in how the name field is used in CUCM?  for example, it seems that it is good practice to add a server by its IP address under System - Server.  if i go to System - Cisco Unified CM - and select a server, there is a field fo...
benmather by Level 1
  • 266 Views
  • 4 replies
Hello, I'm getting the following error when trying Perform Full Sync Now;under LDAP Directories;Failed to connect to ldap://10.1.3.17:3268, check the server IP address or the network connectionWe tried to reset the password, restarted Cisco Directory...
Ayaz Khan by Level 1
  • 559 Views
  • 3 replies
