IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5596 Views
  • 14 replies
here is my system, multiple-sites with Centralized-CM and Unity. remote site talk to each other by G.729. for Unity, it is a integrated Message system, Users access VM by IMAP client, but my customer doesnt buy any viewmail . here are the questions r...
i have a 7940 that will not register with ccm. this is a new office install so there are no other phones that work. the phone is stuck on "configuring cm list". the phone has worked in another office on a different subnet. i noticed during the boot p...
Hi All;I bought CM 5.0 and I need to obtain license file. First I need to have PAK. when I bought CM, nothing came with CM. How can I get PAK first? and where can I find "license registration web tool" in cisco.com to have license file? thanks for yo...
within the same cluster is it possible to have multiple attendant console setups. For example you have attendant console setup for each branch office in different time zones and different main line office numbers. Also is there a license limit on the...
athc by Level 1
  • 436 Views
  • 2 replies
I'm trying to use the bulk import tool to to import some users and i get an error "couldn't create user object" there is also info that the DC service isn't running. but i looked and that service is running.Thanks for your help.
Hi,I need to control a phone not associated to a CCM in .NET, but I do not know how could I do that. A solution would be to create an ITPhone object, but for it I need a line registered and, in my case, there are no possible line to control.Thanks.
