IP Telephony and Phones
Labels
Hi All, I am a newbie on to Voice technology and require your help. My company would like to enable SRST on one of its site and the gateway is configured as h323. Attached is the gateway configuration can someone please help me with the configuration...
NEw 2911Sho ccm - says cucm is downCUCM says fxo ports are registeredI can ping cucm with souce gig0/2 which is voice vlanPhones are not registering either.. I can ping the phones from cucm and I can also open phones in web browserWhat the hell is go...
Resolved! UC520 Live Record
Hi to all, I have a new UC520, I upgrade CME and CUE to last IOS available, all works fine (voicemail, tranfer, etc), but I want to configure the "Live Record" feature. I follow this guide and it seems easy: http://www.cisco.com/en/US/docs/voice_ip_c...
a.crippa by Level 1
  • 945 Views
  • 4 replies
Is there a setting in UCCX 7.X where I can configure and report on short calls, I need to be ignore ringing calls less then x sec from reports. Caller rings in for x sec and rings off- call can be viewed as abandoned so i wish to ignore any call ring...
iptuser55 by Level 6
  • 1523 Views
  • 3 replies
Dear NetPro gurus,One of my customers had their Unity Connection 8.0 integrated with CallManager 8.0 via AXL.  And they would like to migrate the existing integration to integrate with LDAP.  They have the following question:-Since the Unity Connecti...
huntlee by Level 1
  • 583 Views
  • 3 replies
