IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6071 Views
  • 14 replies
I recently took over a CCM environment and need to bring it up to date with the latest security patches. I have been reading a lot of documentation but I haven't been able to find answers to questions below.CCM 4.2(3)OS Image 2000.4.4OS Service Rele...
Hi,I am using CM ver 7. I have configured extension mobility. The main objective behind configuring EM is for login and logout facility for the users.No user is using the Mobility of the EM. I have a requirement like i need the same DN should remain ...
faizal_vi by Level 1
  • 461 Views
  • 4 replies
Hi,I have a doubt related CUCM version and licensing. My doubt is as follows: We have a CUCM 6.0.1 Cluster and we want to upgrade to 6.1.4 version. Is it possible to upgrade from the actual version to the commented version without purchase new licen...
We are running UCM 6.1.2 and using our legacy speakers for paging. The speakers are hooked up to a Bogen TAM B which runs back to an FXS port on our voice gateway. This solution works fine most of the time. However there are instances where when s...
HiI am experiencing an issue with MGCP dial-peers in that when my router loses & regains the connection with Call Manager the MGCP dial-peers alter position in the running config. e.g. :Normal Operationdial-peer voice 999100 pots service mgcpapp port...
norrie108 by Level 1
  • 517 Views
  • 3 replies
