IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6065 Views
  • 14 replies
Hello group, when I'm trying to place call to any number started with "+" , for example +14082221111 my cisco 7961/sip, registered on CM7 send just empty invite with +Do you know if this is a bug ? or sip on CM7 requires special configuration in orde...
Hello,i have the following scenario:1- one gateway (PRI Line interface)2- two RightFax serversi used a SIP protocol between the gateway and the two fax servers , my point is how to configure a dial-peers on a gateway to make an inbound balancing fax ...
jawwalit by Level 1
  • 627 Views
  • 4 replies
HiA customer needs to add in parallel Fax server wich T38 feature activate.Actually we have fax passtru activate with MGCP GW due to ATA endpoint.Does it possible to just configured on the same GW a dial-peer with T38 activate and connected fax serve...
eric.bias by Level 1
  • 349 Views
  • 1 replies
I configured three park-slots with the same number. IP Phones can park up-to three calls by pressing Park softkey. The problem is when you want to retrieve the parked calls you can retrieve only the first call that was parked. The other parked calls ...
