IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5598 Views
  • 14 replies
We are running UCM 6.1. Recently I pulled a CDR report for a department. I only see outgoing calls on the report. Is there a way to configure CDR to generate reports for incoming calls too? Thanks,Yiwen
yiwentan by Level 1
  • 898 Views
  • 3 replies
Hello;I'm trying to install CM 6.0 on a HP DL380-G4 Cisco compatible server. It passes the media check and starts disk and bios checks. But after that nothing happens. No error, no restart, no continue... The last things i see are;Machine passed hard...
yatisspor by Level 1
  • 451 Views
  • 2 replies
Have a Cisco 2811 with IOS c2800nm-entservicesk9-mz.124-22.T.bin, CME Version 7.0(1) two VIC2-4FXO towards PSTN. Alls Call to the PSTN are cut after 2.55 min. approximately, from any of the FXO ports, Can someone help me with this.Thanks
We have a Cisco Unified Contact Center call center system that integrates with our Cisco Unified Call Manager. We are using Cisco 7941 phones with the Cisco Agent Desktop software on our clients in the call center. I have 1 user who is having and s...
caseym by Level 1
  • 346 Views
  • 1 replies
i`m trying to locate any SFTP sw for backing up CUCM. The application needs to be runing even when I logg off the back up server- not when I just lock the machine. I`ve tried FreeFTP`d and FreeSSH but both of which do not seem to work- I thought Free...
iptuser55 by Level 6
  • 422 Views
  • 4 replies
We have multiple offices and would like to send a broadcast message to only one office but right now nothing is going through. We can get into the mailbox but it just drops the call...We are running Unity 4.0Any suggestions would be appreciated. Juli...
julienf28 by Level 1
  • 438 Views
  • 1 replies
