IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5902 Views
  • 14 replies
We are running UCM 6.1. Recently I pulled a CDR report for a department. I only see outgoing calls on the report. Is there a way to configure CDR to generate reports for incoming calls too? Thanks,Yiwen
yiwentan by Level 1
  • 905 Views
  • 3 replies
Hello;I'm trying to install CM 6.0 on a HP DL380-G4 Cisco compatible server. It passes the media check and starts disk and bios checks. But after that nothing happens. No error, no restart, no continue... The last things i see are;Machine passed hard...
yatisspor by Level 1
  • 463 Views
  • 2 replies
Have a Cisco 2811 with IOS c2800nm-entservicesk9-mz.124-22.T.bin, CME Version 7.0(1) two VIC2-4FXO towards PSTN. Alls Call to the PSTN are cut after 2.55 min. approximately, from any of the FXO ports, Can someone help me with this.Thanks
We have a Cisco Unified Contact Center call center system that integrates with our Cisco Unified Call Manager. We are using Cisco 7941 phones with the Cisco Agent Desktop software on our clients in the call center. I have 1 user who is having and s...
caseym by Level 1
  • 355 Views
  • 1 replies
i`m trying to locate any SFTP sw for backing up CUCM. The application needs to be runing even when I logg off the back up server- not when I just lock the machine. I`ve tried FreeFTP`d and FreeSSH but both of which do not seem to work- I thought Free...
iptuser55 by Level 6
  • 426 Views
  • 4 replies
We have multiple offices and would like to send a broadcast message to only one office but right now nothing is going through. We can get into the mailbox but it just drops the call...We are running Unity 4.0Any suggestions would be appreciated. Juli...
julienf28 by Level 1
  • 449 Views
  • 1 replies
Does anyone know where i can find some documentation for SRST? I have CCM6 and several 2800 series routers. A vendor installed the beginning parts of the system and we have built it out ourselves. The SRST sites i set up work but the sites that the v...
Hi all. I am going to be doing an upgrade soon on a site that is currently at CallMananger 4.1(3). They want to go to 4.1(3)SR8, so that they can support some new phones they have. Has anyone done this before? Id like to know if this is a simple ...
jjoseph01 by Level 3
  • 613 Views
  • 8 replies
