IP Telephony and Phones
Labels
I have configured a Cisco Call Manager 5.0 in a Lab with only 3 IP Cisco Phones. They can communicate between them, but I have not been able to configure the conference caracteristic among them. When I intend to make the conference an error message...
Is there a way to use the telephone interface to add names or character strings to historic phone numbers? Right now I have to use the CLI to make a directory entry command under telephony-service but this is no good for the customer to have access ...
Hi all. I have a question I cant seem to get right in my head on how this should work. Im trying to figure out how to implement a potential solution. I have a potential customer that wants to put in a CUCM and they have 4 sites total. One main si...
jjoseph01 by Level 3
  • 446 Views
  • 4 replies
Hi there,Is there a way to call from one AA to another AA in the same CUE? Currently, when I am in an AA and dial another polit number, an error message 'invalid phone number' comes out.What I want to achieve is to have one AA that allows external tr...
Chuan Liu by Level 1
  • 268 Views
  • 1 replies
Hi Guys,I'm trying to upgrade a CUCM 4.0(2a)sr1a (running OS version 2000.4.2sr10) to CUCM 6.0. After I got rid of all of the Callmanager Upgrade Utility errors.But when I try to run the Database Migration Assistant (v6.0.1a) I'm hitting a couple of ...
pijssel by Level 1
  • 273 Views
  • 1 replies
If I want to test some network settings (routing etc), what is the best solution to test it, but cluster should work fine after test?Should I switch off cluster? Or should I switch off only subscriber? If I switch off subscriber what services should ...
