IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6133 Views
  • 14 replies
HiI have built hardware refresh CCM 4.1.3 Server. After restoring backup database with BAR, I cant access ccmadmin page. It gives error such as you are not authorized to view this page. The original server had MLA and integerated with IPlanet directo...
guest by Level 1
  • 219 Views
  • 1 replies
Dears,I have Cisco MCS 7845 H1 servers (2 disks using mirroring) and I would like to have a full weekly backup of my publisher.For this, every week, I will remove the hard disk in slot 1 and replace it by another one.What is the best way to do this?D...
CCM 4.1(3)sr5bLoging in to CCM admin page gives the following error: Cisco CallManager CDBLException Dump: [SQL login failure] Administration You do not have access to this page.This is a cluster of 3 subdcribers and one publisher. IIS wa re-started ...
Hi all , Since the 7936 conference station has only one button and can have a dual channel it can be used max for 3 party call only ???? is there a way i can configure the station with more that 2 people i can call from it using a cmeTHANKS...
alanhong by Level 1
  • 617 Views
  • 1 replies
